hi everyone im currently in the middle of a new build and am looking for some advice from the pro's
im going from a unlocked amd barton 2500 M 1.8 @2.5ghz and a 9800 pro 128mb.
the spec is
P4 D 805 @ 3.6+ hopefully 3.8 with the zalman CNPS9500 LED
ASUS P5B Deluxe
2gb ddr2 800
250gb seagate 7200.10
ASUS 8800 GTX
as u can see i bought the 805 before conroe doh! but i will plan on adding one later on maybe drop in a quad core when they reach a good price and overlock as good as the 805.
now which psu should i go for?
personally i had the seasonic s12 600w silent in mind its around my price range (under £100) although i would like to save some pennies as i paid like 400 for the graphics card.
i have seen the enermax 530w going for £65 and the antec true power trio 550w also for a little cheaper only £20 mind you.
silence would be nice but all those models have 120mm fans but my main worry is 530w enough? or should i fork out the extra £30 for the seasonic 600 keeping in mind that the same psu might have to run a quad core or a heavily overlocked 4.0ghz dual core conroe in future.
thanks in advance for your imput
im going from a unlocked amd barton 2500 M 1.8 @2.5ghz and a 9800 pro 128mb.the spec is
ASUS P5B Deluxe
2gb ddr2 800
ASUS 8800 GTX
