Hi all,
I'm a long time buyer for OCUK but never really used the forums, I've been reading up on components for a new system and I've managed to narrow it down, I just wanted some advice as I've got a bit out of touch with the scene in recent years and I don't trust my own judgement anymore!
Just to advise of my current system first of all:
Asus P6T
i7 920 @ 2.67ghz
OCZ Intel i7 6GB (6x1GB) DDR3 PC3-10666 Triple Channel
BFG Geforce GTX 295
I reckon I'm about due an upgrade to a DX11 capable GPU and faster CPU, was thinking along the lines of the below:
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM £239.99
Corsair Hydro H70 High-Performance CPU WaterCooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) £79.99
Asus P67 Sabertooth Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £214.99
OcUK GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card x2 £539.98
Corsair Vengeance 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel Kit (CMZ12GX3M3A1600C9) £149.99
Corsair HX 850W ATX Modular SLI Compliant Power Supply (CMPSU-850HXUK) £143.99
Total: £1,368.92
I had considered a few other options, 2x 6950's (unlocked to 6970's) but going by benchmarks I've seen (http://www.guru3d.com/article/geforce-gtx-570-sli-review/9) the GTX 570's in SLI seem to out perform 6970's in Xfire? (albeit by a fairly small margin for £120 more)
Also I know it's not really a good reason but the last Radeon I had that I was happy with was a 9800 Pro. I bought a 4870x2 before my GTX 295 but sent it back as I had several issues with it and that kind of put me off Radeons.
I also considered 2x GTX 480's in SLI, but reconsidered once I saw how much heat they generate and also the amount of power they consume.
I have a few (probably stupid) questions:
1. Does anyone see any problems with the above setup? Anything you would change? (bear in mind I'm already beyond what I wanted to spend!)
2. Do you think the PSU is sufficient? If so does it give enough headroom for overclocking the CPU/GPU's?
3. I noticed in the pre-overclocked bundles that they contain dual channel DDR3 as opposed to tri channel, and also that they only contain 4gb RAM? Is there a reason for this? Am I making the wrong choice with tri channel or going overboard with 4gb+ of RAM? I only went for 12gb over 6gb as price wise it's only marginally more expensive.
Any advice is much appreciated, apologies for my ignorance but as I said I'm so out of touch with the scene these days I need help from people in the know!
Cheers
Asus P6T
i7 920 @ 2.67ghz
BFG Geforce GTX 295
Total: £1,368.92
Cheers
