Advice on new build
19 Feb 2004
Stoke-on-Trent
I picked up a Ryzen 3700x at the overclockers birthday sale at the weekend... now i need the other bits :)
I have an EVGA 2070 Super and windows 10 already and am looking at getting the following bits
My basket at Overclockers UK:
Total: £563.14 (includes shipping: £13.20)​
Its been ages since i've built a PC so im not sure if all the parts are compatible. Are there any glaring mistakes? Am i missing Anything?
Thanks in advance
Hi
Looks good for the most part, but I would go with some cheaper Ram and a different Psu. Also the Fractal Meshify should have better airflow.
Added a couple of extra fans for the front, and you can put the pre-installed front fan at the top/rear.
The Arctic fans will only use a single fan header as the fans have a splitter cable. The Splitter cable is so you can plug both rear fans into the left side header.
The Scythe cooler is optional if you already have a cooler, or are using the stock one.
Total: £552.98 (includes shipping: £13.20)​
Brilliant, thank you!
why the change in psu and ram? Is it purely a cost thing?
The TXM has better internals, although you lose the full modular part. If you want a fully modular Corsair unit then I would go with the RMx.
Yes the 8 Pack ram is very good but it is expensive. If you want to tinker with overclocking the Ram then you can swap to the Crucial Ballistix Sport LT. There is also the Patriot Viper if you want 3600MHz. The timings are not quite as good as the 8Pack kit but it is £50 cheaper.
Total: £181.68 (includes shipping: £8.70)​
Thank you for your time! Got the fully modular power supply but kept the ram you originally recommended:)
