- 20 Feb 2011
hi all, first post here as i figured i could use ur advice
I need a new CPU HSF (is that correct name?) and i want everyones advice.
I want a fan that will work with an athlon ii x2 250 regor. it needs to be smallish preferably and VERY quiet (or as quiet as possible).
Preferable within a £20-£40 price range,
Here are my system specs:
OS - Windows 7 Home Premium 64 bit
CPU - AMD Athlon X2 250 @3.0ghz stock HSF
RAM - 4.0gb (2x2gb module) Corsair Dual channel DDR2 @800mhz
MOBO - ASUS M2N68 Plus (AM2+ i believe...)
GRAPHICS - ATI Radeon HD 4870 1GB @770 core, 900 mem
HDD1 - 500GB Seagate 7200rpm 32mb
HDD2 - 250gb Maxtor something or other (storage)
i may do i slight OC on the Athlon... but not much
temps are 30c stock and 78c full load, so id like it to be cooler
heres a pic of the inside of my tower (a jeantech aqua) so you can get an idea as to how much space i have..
In the future i am upgrading to:
CPU: AMD Phenom II X6 1090t 3.2ghz with no OC.
RAM: some nice 4gb modules (2x4gb) so i dont want the cooling fan to cover RAM slots if possible so i can upgrade to 12/16gb.
MOBO - ASUS M4A88T-M
so i neeed the Cooler to be compatible with the new MOBO/CPU.
i was initially looking at artic cooling freezer pro 7 rev2 but im not sure how loud this is, + its quite large.
also, is this the best mobo choice, its £60, is there anything cheaper which will fulfill the same needs/more...
thanks for the help, much appreciated.
