Hi,
I'm in search of new system and based on my requirements I've kinda arrived to specs but when I tried to do a custom build using "system configurator" (here at overclockers.co.uk) the price shooted up around to £1300
whereas my budget is around 800. I'm not sure if i did any mistake choosing components.
My application is basically CPU intensive and I would be needing a CPU near to "Intel Core i7-3930K 3.20GHz" with 8GB (minimum) or 16GB (recommended). I would also do some gaming when no load on it.
So my rough specs:
Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor
8/16GB RAM DDR3
Asus P9X79 PRO Intel X79 (Socket 2011) DDR3 Motherboard
1GB/2GB VRAM Graphics card
Cabinet with 750W PSU with adequate cooling
Intel SSD 120GB Drive
Basic DVD Drive
**No game controllers required
**No Monitor, K/B and Mouse required
** NO OS required
Now, Can anyone please suggest me full config "near" to the above configuration (with break-up price) so that it can be purchased within my budget limits. Sorry, If I'm asking for too much
Thanks much,
Bhvn
So my rough specs:
8/16GB RAM DDR3
Basic DVD Drive
** NO OS required
Thanks much,
Bhvn
) buy a 3930k cos they want it not need it,its a very powerfull processor and id have thought youre very unlikely to fully utilise it! set your sights a bit lower and im sure your find yourself a suitable rig for that money
. im sure someone will slate / question this
