Advice on OC Please
30 Mar 2008
Overclockers Bundle:
Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard
OCZ 2GB (2x1GB) PC2-8500C5 1066MHz SLI-Ready Edition Dual Channel DDR2 (OCZ2N1066SR2GK)
Tuniq Tower 120-LFB CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
Arctic Silver 5 Thermal Compound (3.5g)
OcUK Overclocking Guide - Abit IP35 Pro, Q6600, 2GB OCZ PC-8500, Tuniq Tower, AS5
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail
PSU Jeantech artic 600 watt bought this as it had a fair review on Tom's hardware..
Settings:
External clock 365Mhz
DRAM Speed 1.1.25
PCI Express clock 101Mhz
CPU Core Voltage 1.4950v
DDR2 2.2v
MCH 1.37v
CPU VTT 1.27v
ICH 1.15v
ICHIO 1.55v
CAS latency 5
Ras to Cas 5
Ras Precharge 5
Precharge Delay 15
stress tested (ORTHOS) for 7 hours all ok temp up to 45C idle 22C
These are all settings supplied with the parts apart from CPU Core Voltage. iIhave tried the specified 1.4525 but kept failing the stress test.
Is this voltage ok to use spent around 4 hours adjusting speed and volts until i got something that worked..ps. noob guide is great..:)
If you have MSN, my email is in trust - I'll talk you through the settings you need, though if it's stable dunna worry about it.
wow quick reply thanks...
spotted my mistake thanks...
full story, bought the bundle a few weeks ago put it tougether and could only get a stable system on auto settings..
RMA the whole and it turned out i had bent a pin on the motherboard (lesson to be learned there)
anyway got it all back checked out the board and could only find one bent pin, so I decided to bend it back into place and it seems now to be working ok..:)
put all the supplied settings in and it all works great apart from having a higher:
anyway in answer to your question.. i Think:confused:
+12v V1 19A
+12V V2 19A
just wanted to make sure I was not doing anything stupid (AGAIN) :confused:
Thats OK - some people have had trouble overclocking if their PSU only has 1 4-pin connector for the motherboard.
Chip voltages vary. So are you running stable now or are you still having problems?
Just keep microfibre cloths away from sockets. a lot of people try using them to clean AS off the surrounding area - disaster lol.
I did have an old psu in there with one 4-pin but bought this one after advice it has one 8 pin and one 4pin I am using the 8 pin. I take it that means i am using both rails :confused:
It seems to be stable as I said 7hrs on ORTHOS. No problem.
So is that voltage ok..
AS???
