I am trying to overclock my processor at the moment but before I overclock it further I just want to check some things.
Here are the results from CPU-Z before overclocking:
Here are the results after my first OC:
The system is stable but I noticed my memery frequencies have gone up and I'm not sure how much I can increase them by safely. Here are the options I have in my BIOS (this is just the screenshot from the motherboard manual):
The K8 Ratio is set to default (I guess this is just the multiplier).
The RAM I have is Corsair Value Select 3200 and was previously running at 200 MHz but I guess it's at a 1:1 ratio at the moment because it's now running at 210MHz (the amount that I have OC'd by so far).
My question is really should it be safe to continue overclocking the CPU and just let the RAM frequencies increase with the CPU frequency? And how far should I be able to push it? Please bear in mind I know very little about overclocking
Thanks.
Thanks.
