Advice on Pre built system
12 May 2013
Yate ,Bristol
I've been wanting to upgrade my current system for a while, but rather then upgrading, and doing incremental upgrades, I would rather just buy a new PC. As you can see my CPU is now my biggest bottleneck in terms of GPU performance.
I will want to add another GPU in the future so a good PSU is a must,& a motherboard & case that will take either sli or xfire .
My budget is £1500 & I currently use my PC for gaming & occasional video encoding
The board will support Sri and crossfire but you probably will need a different psu . Maybe something about 850w to be sure. Seasoning are a good brand. If you are buying the system upfront you can call ocuk and get them to put a seasoning 850w in there for you and see what the price would be .
Damn autocorrect . Seasonic not seasoning .
