advice on purchease
9 Aug 2010
i have an obsidian 800d I'm fitting three fans to the roof mounts to improve case temp Ive purchased
3 x Scythe 120mm Slipstream 1200rpm 0.26 A
1 x NVXT Sentry LX Supports up to 4Watt per channel
2 x 3pin 4 fan Y Cable
what I'm trying to do is control the three roof fans on a single channel off the Sentry LX
then going to run the 2 140mm corsair case fan on another
the 140mm HDD hot drives on another and the CPU fan on another
leaving a spear channel
Will i have any problems running 3 x Scythe 120mm Slipstream 1200rpm 0.26 A on one single 4watt channel off the sentry Lx found know easy way to find this out
why do fan manufacturers use amps and fan controllers measures in watts per channel
