Advice on RAM upgrade (3600MT/s DDR4)
itm
itm
22 Feb 2011
I want to increase (ideally double) the RAM on my Proxmox host. It runs on a Ryzen 7 5700G / MSI B550M Pro-VDH. Current RAM is Kingston Fury Beast 64GB (2x32GB) 3600MT/s DDR4:
*no competitor links*
...but this is now discontinued.
Can anyone recommend alternative 2x32GB RAM modules, as I'm confused between the MT/s and MHz speed ratings. Most outlets quote speed in MHz, so for example can I use any DDR4 3600Mhz RAM in parallel with my two existing 3600MT/s modules?
I will probably also look for second-hand RAM to keep the costs down.
whilst technically not quite true, they are used interchangeably.
so, for the purposes of buying ram, MT/s = MHz
So would this be fine alongside my existing RAM, for example?
Corsair Vengeance LPX (Low Profile) DDR4 64GB RAM (2x32GB, 3600MHz)
Please remove your links to other marketplaces and retailers. The forums are provided by OCUK and don’t low links to other stores.
fine is a relative term
in theory, yes it should
BUT
running 128GB of ram at 3600 is an EXTREMELY TOUGH ask for the memory controller
i would not be surprised if any of the below applies:
1) you couldn't
or
2) will need to run at reduced frequencies/slower timings to get it to run without errors, and/or
3) bump up the CPU IMC voltages (maybe to potentially unsafe levels)
BUT
1) you couldn't
or
Oh OK. So what would be the upper limit of RAM that could comfortably run at 3600?
silicon lottery
in reality, you running 64gb @ 3600 already means your CPU memory controller is extremely good and could probably be considered a golden sample
