- 12 Dec 2013
- Nuneaton, UK
Hi guys,
My rig seems to have developed a strange fault in the past few weeks and has really got me confused as to what it could be!
As a last ditch attempt to solve it I'm seeking advice on here!
The issue at hand:
My System reboots sporadically! Typically it will last 40-30 mins before its first encounter. This is regardless of load; its happened from 30 mins of internet browsing but also under heavy to moderate load playing games.
The only consistent trait to this is each time I restarts, the next time will be considerably less than before. Example first restart could be as stated (30 or 40 mins) the next time it will be between 10-15mins.
I have tested the PSU as my first instinct was that it was power related, however all rails fall into ATX standards.
my next instinct was overheating, which I still think could be a major part of the issue (ill talk more further down*)
Temps peak around:
32 degrees for the CPU (H50 cooler installed)
38 - 40 on the GPU
*However the chipset seems to get rather hot (hot enough I wouldn't want to touch it for any longer than a few seconds!)
Specs
i7 2600k @ 4.4ghz
Asus P8-Z68V
8GB DDR3 1600
2GB HD6950
Coolermaster GX 750W
Any advice as to how to tackle this issue or what it could be would be greatly appreciated.
Cheers,
SC
The issue at hand:
Temps peak around:
38 - 40 on the GPU
Specs
i7 2600k @ 4.4ghz
Asus P8-Z68V
8GB DDR3 1600
2GB HD6950
Cheers,
SC
