Advice on Reducing Temps
10 Jun 2006
Northumberland
Hi Guys,
I am a little concerned with regards to the temps in my case.
At the time of writing this my lapped Q6600 (3.2GHz 1.3vcore) is idling at 39,38,36,36. Using a D-tek fuzion with 102.3 rad. I have 3 fans sat on top of the rad pulling the heat out of the case.
According to Everest my motherboard temp is at 44 celsius and my 8800GTX diode is at 64 celsius.
I also have a Asus D2X soundcard in there and they can get pretty hot however I do have a side case fan blowing onto this.
I have thought of RAM heatsinks, accelerator kit for Fuzion water block, 3 more fans on the rad, watercooling the GPU I mean the list goes on.
What would you guys do to bring temps down a little or are these temps okay bearing in mind the hot weather we're having in the UK atm.
**********Edit**********
Room temp is hovering between 24 -27 celsius at the moment.
Running Prime95 for 15mins puts temps of CPU at 52,51,50,50 with all fans at max.
Case is a Lian Li G70B with 120.3 rad at the top of the case with 3 x 120mm Yate Loons pulling the hot air away from the case.
Got a 120mm Noctua NF-S12 at the bottom fron of the case blowing across 4 HDD's.
Rear 120mm acting as an exhaust and a side 120mm fan blowing onto GPU and Soundcard
Well after changing all 3 fans from pulling hot air from the rad to the outside of the case to them now blowing into rad from the outside my temps have changed considerably to: -
46,45,45,45
happy days
