- 30 Nov 2008
I currently have 4 gb of twinmos ram (4x1gb) running in dual channel mode, having looked at CPUZ it seems my memory is running very slow, wanted to alter the timing, went on manufacturers website and all I can find is cut and paste below!! can anyone help me set these?ps. i am running 32-bit vista with no trouble using 4gb!
thanks in advance
Capacity
PC2-6400 / DDR2-800 240 Pin Unbuffered DIMM
2GB 1GBx2 64Mx8(x16) non-ECC DDR2 SDRAM
Features
Ensure system stability with the lowest MTBF feature
Single module perform Data Transfer Rate up to 6400MB/s
A whopping 12.8GB/s of memory bandwidth
Easily expand extra modules anytime
The matched pair of dual channel kit modules are all been verified in the dual channel environment and proved through testing to achieve high performance and stability
Specifications
Double Data Rate architecture
Bandwidth(max): 6.4GB/s
JEDEC standard
Serial Presence Detect support
MRS cycle with address key programs
* CAS latency: 3, 4& 5 (clock)
* Burst length: 4 & 8
* Burst type: Sequential & Interleave
2 variations of refresh
*Auto refresh
*Self refresh
thanks in advance
Capacity
Features
Specifications
JEDEC standard
*Auto refresh
*Self refresh
