Advice on Shuttle Build
11 Mar 2009
Hi everyone, long time lurker but first post. I hate to start with a question rather then an answer but here we go....
I intend to replace my full size server with a Shuttle KPC K45 http://www.overclockers.co.uk/showproduct.php?prodid=FS-118-SH But before i do, can someone just confirm that the 100watt PSU that it comes with will be OK to run an e5200/2 gig of ram and two 1000 gig samsung spinpoint F1's ?? (no optical drive or GFX card, in fact no monitor at all)
I have had shuttles before several years ago (AMD Barton era) but they were all 200/250 watt and small harddrives. I assume modern components are much more energy effecient but 100 watt seems terribly low.
I intend to use this machine 24/7 to download (and verify/rebuild) and serve media to 4 networked DVD players, with the occaisonal re-encode and gordian knot backup. The machine will not be overclocked as i prefer stability and low temps for an always on machine.
If it will power this setup fine my electricity bill thanks you, as i use a 550 watt PSU in my current server, albeit with four 1000 gig F1's.
Thanks in advance for any advice, on the above and also whats the best cheap dual channel RAM to buy, nothing fancy just stable.
off the top of my head I think the E5200 uses 65w, the hdds will use about 8-10w each i think. add ram and motherboard power and a dvd player and I don't think I would be happy doing that.
I think you can pick up a 250w shuttle psu for about £50
You would be surprised how little power you really need. For reference; I am hoping to get the spec in this thread running on a 120W power supply. I am told that it should run, just waiting for the components to arrive so that I can confirm. :D
Given my spec, I should imagine that your hardware will run on a 100W power supply. The only concern would be the extra current draw from the hard disks when they first spin up. The Western Digital Green series drives are supposed to minimise this.
The E5200 TDP (Thermal Design Power) is 65W. This is quite different from the actual operational power usage. From what I have seen, it is likely that the E5200 will use up to around the 25-27.5W mark under full load and as little as 1.5W when idle.
Thanks for the replys so far, it does seem like there are two opposing views so i'm still unsure, but i appreciate any and all input.
I chose the e5200 as it seems the most cost effective chip to me, and i dont wish to spend a lot of money if i can help it. I just wonder if there is any RAM that suits it in particular, or will any old dual channel kit do?
Just to clarify this machine will have NO optical driver or GFX card, and in fact will be run remotely so no monitor or mouse and keyboard either.
You have to buy a usb optical drive, there is a on board graphics, you will need to buy a keyboard and mouse, monitor/tv to use it.
No i will not use a monitor/or optical drive at all, only to install windows/linux initially via the ide port and a driive balanced on top of the case and the onboard gfx card, After that it gets shut away with a 48 port switch and used only via remote server software. I usually maintain a 70(ish) days uptime between restarts
This is how i currently run my full sized server. I have a fully (hardwired) networked house with 40+ rj45 sockets and this machine will serve media and act as a internet gateway to them all (roughly four or five at any one time)
Any more opinions on the 100 Watt PSU??
Also i have just realised that the e5200 chip is 800 FSB but the memory is only 667, will this be a problem? can the chip still run at full speed?? will this cause any stability issues?
The nest shuttle up that takes 800 memory is £100 quid more expensive and i really dont want to spen that much.
