Hi All,
I currently use a gaming machine with standard, crappy PC speakers run via the onboard sound card and wanted to beef up the sound quality a bit for when I want to listen to music, be that through Spotify or via CD (yeah I have loads of those still).
I read on the "What desktop speakers are you using" thread that some people have a AV Amp connected to the PC via HDMI and a couple of speakers connected to the amp, I like the sound of that setup but the room I am in is small so was also exploring getting a sound card for the PC and attaching speakers to that soundcard.
I've a couple of questions.
1: If going the sound card route can someone recommend a decent soundcard, looking at no more than £100 ideally, and a recommendation for speakers too.
Sound card wise I saw this and wondered if anyone had any experience with it.
Speaker wise I saw these, would these ft on that sound card above?
2: If i can get an AV Amp cheap enough, does the HDMI just connect into the graphics card HDMI slot in order to make the connection?
