advice on spec
22 Nov 2006
Hey Guys. what do you think of this spec? The use of the computer will be for gaming.
heres the spec:
Pentium 4 PCI-Express Motherboard
Black Case
Intel Core 2 Duo 6400 processor (2 x 2.13G
1GB DDR2 Memory
160GB SATA 7200rpm Hard Drive
512MB Radeon X1800xT
DVDRW (Dual Layer)
Uprated 500W Twin Fan PSU
which will come to a total of £697 inc VAT.
Cheers guys!x Teddy :cool:
Welcome to the forums, do you have any more information on the motherboard? The description means it could be almost anything and the PSU might be a generic offering as well. You could build this system with parts from OcUK for about £45 more but you get 2gb Ram, one of the best socket 775 motherboards for overclocking and a good quality case and PSU. The graphics card is a 256mb model though, however this is fine unless you are playing at 1600x1200 or above normally. Actually probably a better option is to go for a 6300 chip and a better cooler as you can easily overclock to faster than the 6400 is at stock.
Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail £129.99
(£152.74) £129.99
(£152.74)
Connect3D ATI Radeon X1900 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail £149.99
(£176.24) £149.99
(£176.24)
Corsair 2GB DDR2 Value Select PC5300 Dual Channel Kit (2x1GB) (VS2GBKIT667D2) £139.99
(£164.49) £139.99
(£164.49)
NEC AD5170 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM £18.99
(£22.31) £18.99
(£22.31)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £87.99
(£103.39) £87.99
(£103.39)
Antec NSK6500 Super Midi Tower Case - 430W PSU (CA £58.99
(£69.31) £58.99
(£69.31)
Samsung SpinPoint P HD160JJ 160GB SATA-II 8MB Cache - OEM £36.49
(£42.88) £36.49
(£42.88)
Sub Total : £622.43
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £10.95
Vat : £110.84
Total : £744.22
yh thats sounds lovely. thanks m8. i have a friend that can build it for me aswell. is there any other prices like delivery?
thanx m8
Teddy :cool:
Delivery is included via City Link so £744.22 is a total price. You probably don't even need your friend to help you build it, PCs are pretty simply now but if you would feel more comfortable then ask them to watch over you while you do it. :)
