I currently have the following:
DFI Lanparty UT NF4 SLI-D
AMD 64 3500 Winchester
2 x 512mb OCZ PC3200 DDR400 Platinum Rev 2
The time has come to upgrade to 2 GB Ram.
What I'm looking for is - what memory would people recommend to ugrade in the above config (2 x 1GB). Would I need to lower the command rate to 2T?
I'm thinking maybe G.SKILL PC3200 and have been advised I'd probably need to run at 2T with my current CPU.
However, if I were to upgrade the processeor at the same time to an AMD 3800 X2 - what would be recommended then?
I'm not particularly looking for overclocking - Im just looking for good fast memory with the least hassle / fuss to install (I know DFI boards can be fussy from past experience!). Being able to run at 1T would be nice.
Your thoughts much appreciated!
Damian
Damian
