Advice on system for video editing
jos
jos
10 Feb 2007
Hello, I am interested in video editing with Photoshop I am using the 3.2 system -not the fastest. I am considering moving to the core2 6400 or 6600 is it better to wait until April til the prices come down? It is being used for video editing What advice would you give me on overclocking safely to achieve the best result? As I am new to this and am interested in building my own PC what would you recommend I go with?
One more problem -I suspect that I have clicked and formatted my dvd drive by mistake Now I am getting this message -this file does not have a programme associated with it for performing the action Create an association in the Folder Options control panel. This procedure however will not work for me and I have tried to associate Power dvd to it but no luck either. Any advice or ideas on this would be most appreciated I know the power of the Forum you have guided me well on many occasions Thanks jOS
thanks for getting back os soon,i have a sony 3 mhz,very old 2001 and very slow,it does have a storm 2 card,also a 3200 mhz i865pe,canyon m-b,just a firewire port,both pc have 1 gb,i would like to spend about 5 0r 6 or so,cheers jos
sorry but it is not a wind up,i do not know a lot about the pc to let you know what i have, cheers jos
well you have certainly picked the right software. photoshop is superb for video editing.
on the hardware front, i suggest you downgrade, as high spec components can hinder the photoshop video rendering process. photoshop also renders video best when combined with a cisco router, so see if you can download one
hope this helps you :D
Just asking about the spec's of your present pc to see if any of part's could be used on an upgrade . If cant find or workout the spec's of the old pc i would not recomend building a new pc by your self.
I have build this pc about 4 years ago, it works but I have to keep xp in one drive all the time, it may be because there are 2 sata d drives I really loved doing it ,but I do need advice on what to used as you can see I am not great at that because I do not know anyone to advise me,I have downloaded Sandra software ,on the sony vaio pc I do not have office on it to copy the spec’s, what do you think of this one, hope you can make this out,and thanks for taking the time cheers jos
Processor
Model : IntelPentium 4 CPU 3.20GHz
Speed : 3.20GHz
Performance Rating : PR4001 (estimated)
Cores per Processor : 1 Unit(s)
Threads per Core : 2 Unit(s)
Internal Data Cache : 8kB Synchronous, Write-Thru, 4-way set, 64 byte line size, 2 lines per sector
L2 On-board Cache : 512kB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector
Mainboard
Bus : ISA AGP PCI IMB USB FireWire1394 i2cSMBus
MP Support : 1 Processor(s)
MP APIC : Yes
System BIOS : Phoenix Technologies, LTD 6.00 PG
Mainboard : Canyon I865P/PE
Total Memory : 1GB DDR-SDRAM
Chipset 1
Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller Host-Hub Interface
Front Side Bus Speed : 4x 200MHz (800MHz data rate)
Memory Bus Speed : 2x 200MHz (400MHz data rate)
Video System
Monitor/Panel : Plug and Play Monitor
Adapter : NVIDIA GeForce4 MX 440 with AGP8X (Microsoft Corporation)
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : SAMSUNG SP1614C (149GB)
Hard Disk : BUFFALO USB Flash Disk USB Device
CD-ROM/DVD : JLMS XJ-HD166S (CD 48X Rd) (DVD 6X Rd)
CD-ROM/DVD : PIONEER DVD-RW DVR-110D (CD 63X Rd, 63X Wr) (DVD 8X
jos
Hello again,I hope that I have not caused ant offense to any member, I am new to this, but I would like to know what the last post is about, I am just looking to build a new pc for video and photos, I used premiere and Photoshop, regards jos
jos
Thanks for the reply, I thought that what its about, I am not trying to be smart last thing on my mind, I just don’t know a lot about what I have in the pc ,I got advice on what to buy and I have seen friends build there pc, and I did build this one myself some years ago, it may not be very good but it does work, so please don’t thing that I full of anything, I may not be very good at writing it all down, I just looking for advice because I had been reading this forum for years and think it very good, also I am very sorry if I have caused offense to anyone, none was intended, regards jos
jos
Back again, I found it hard to understand why because I did not know enough about the pc that only a couple would try and help, because of one member who now writes this -
Harvesting music and pornography, playing a small number of games for a couple of hours a day on average, trolling most well-known English Futaba imageboards, creating offensive animated gifs.
__________________
And he thinks I’m full of it, Jos
