- 21 Feb 2013
Looking for advice, what i can change/add.
Well it will mainly be for gaming, i just want a pc that will actually play stuff decently, ive been trying to maintain the current one i have now for years adding new parts or replacing and its just on its last legs now, never had the money to build one for myself until i started working.
So yes please could i get some advice on what to change having a little trouble. The budget is around £600-£650 could go higher lower a bit either way.
Here is what i have been looking at (Be gentle
AMD Bulldozer FX-6 Six Core 6200 Black Edition 3.80Ghz £104.99 - This is probably the one that i most need help with,and im not up to date on amd at all, i would go with intel but they seem pricier.
Corsair Hydro Series H55 All-In-One Liquid Cooler for CPU £52.99
ASRock 970 Extreme3 AMD 970 (Socket AM3+) DDR3 ATX Motherboard £65.99 Again not sure on this, it looks like it has good specs and be just what i need.
Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3 £41.99
Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache £61.99
corsair Force Series 3 120GB SATA 2.5 £85.99
CiT Vantage Midi Mesh Gaming Case - Black £35.88 - not sure on the case at all what makes a good case?
power supply undecided
Sapphire HD 7850 2048MB GDDR5 £169.99
== £619.81
Thanks for your time lads.
)AMD Bulldozer FX-6 Six Core 6200 Black Edition 3.80Ghz £104.99 - This is probably the one that i most need help with,and im not up to date on amd at all, i would go with intel but they seem pricier.
== £619.81
