Advice On This LCD
28 Jul 2006
Hi
Basically just looking for some advice on this tv
http://www.max.tv/product-detail.asp?number=685GB
Now i know its from max.tv and it isn't going to be the best LCD by any stretch but what do you guys think of it for £399? Apparently its a 7 generation samsung screen with HDMI. I have also found out it has a 8ms response time.
I am a student so cant really afford the lastest kit but I thought this one looked pretty good for the price and I'm going to be using a tv primarily for gaming so if anyone could give some views and advice it would be much appreciated!
For the spec offered, it sounds too good to be true mate - I think a few guys wouldn't go near this one
I can't really offer much of an opinion on the set but the does appear to be a better set on Amazon for £379.99. It's a Digihome LCD26701HD 26" Widescreen HD Ready LCD TV
I think it looks a little better than the one you were looking at and it seems to be one of the screens that a lot of people sell but change the name on.
Can't make any comments about how good it is as I don't have it but a couple of reviews on the web site.
Good luck in your hunt though
