Advice on trimming me plums!
1 Jul 2003
There's a voice that keeps on calling me.
Hi All,
Im after a bit of advice on dealing with my plums, well the tree! i get brilliant yellow plums, but ive let the tree just grow and grow, so im after advice on how to trim it down and when to do it.
Can any of the greenfingered forumites help.
1 Mar 2010
we can't see if there are any plums there now. ?
Make sure you cut it cleanly with a saw or anvil-cutter, important to avoid disease getting in - I bought some resin to apply to a treasured palm tree when I pruned that.
my suspicion is Autumn after the tree has pulled goodness back into it's core, ready for some upcoming spring growth, to try and get some fruit next year.
22 Nov 2007
Staffordshire
I'm pretty sure you prune plum trees early spring or mid-summer. It a case of removing some of the older branches. The new will then send up loads of new shoots, so you will need to prune these back to keep it under control.
