Advice on upgrade build
23 Jun 2009
Hi All,
Looking to do a bit of an upgrade to my current setup and i have put the below together. Any suggestions on tweaks or upgrades i could do to reduce the cost or improve the performance even more?
My budget is around the £600 mark so i cant really move to far away from that. I am also looking to downsize the case as i have a full on NZXT tower at the moment that takes up way to much space with a new family around.
I have an SSD and SATA drives, decent PSU and monitor/mouse/keyboard
I am also currently running a i5 2500k (clocked at 4.2ghz) and a GTX970
So the upgrade list is
Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - OEM
Stock Code CP-580-IN
£229.99*
Arctic Silver 5 Thermal Compound (3.5g)
£5.99*
Avexir Blitz Original Silver 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Memory Kit - White
£109.99*
Corsair Hydro H90 140mm High Performance Liquid CPU Cooler (CW-9060013-WW)
£85.99*
BitFenix Prodigy M MATX Cube Case - Midnight Black
£69.95*
Gigabyte GA-Z170M-D3H Intel Z170 (Socket 1151) DDR4 Micro ATX
£104.99*
Thanks
Should also note i have a Rift and i want to make sure i can continue to take advantage of new games and apps that come out for it for a while to come
