- 20 Aug 2012
Hi all.
We built an Overclockers tower gaming rig - probably the best part of 2 years ago.
Its base spec is:
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor
Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 2133MHz Dual Channel memory
MSI HD 7950 Twin Frozr III Boosted edition 3072MB GDDR5 PCI-Express GPU
I seem to remember that you can crossfire the graphics cards (basically add another?)... but I can't find one to match the above and its all unknown to me. I assume life has moved on and that option is now gone.
Only reason I ask is my other half ran a new game today and the frame rate was 29 - way down on the days when we started.
Options? I seems a real shame to bin the perfectly good 7950 above - plus I don't want to bash a pile of cash on the head for minimal improvement.
Just as a side note, we have never overclocked the system. I looked into doing that when we built it, but just wasn't confident enough to have a tweek.
Does overclocking the graphics gain you all that much?
We basically selected the pre-set 'extreme' setting and left it at that.
Any guidance gratefully received
Its base spec is:
