Advice on Upgrading
3 Jun 2011
B'ham
Hi,
I've been asked me for help in making his work PC capable of playing the latest games (Bioshock Infinite especially) so he is looking to buy a GPU and possibly a new power supply if needed. Problem is that his PC is a Dell Vostro 430 and it's a small case. If people could help advise me on what GPU would fit inside and if I would need to get a new power supply for it. I think the power supply is currently 350w and a gpu of G310 gpu. Looking at a budget of £100 too.
Going to be honest, i don't think you'll get a good enough GPU in that rig to run it at medium settings!
Though we can give it a go:
Do you know what connectors the PSU has? Does it have any 6 Pin PCI-E?
I think it has one, although I can't open it up right now to check but I will be opening it up later today to double check.
