Hi all
My 1st OC going very well
If those temps are right, there's room for more too.
Speaking of which - what exactly are these 2 temp readings, working from the top down?
1) That's the system temp I think, yes?
2) This is the one that I've got my eye on - at idle it's about 36*C but as you can see it goes up a lot under load. Is this likely to be the Northbridge (or Southbridge) temp?? What's a safe limit if it is?
Regarding the vcore limits.....I've read Jokesters excellent sticky (and others) on how to begin OCing, and the safe amount on how much to increase the vcore mentions going over by 20% of the default limit.
Now maths has never been my strong point, but I reckon that means if my default is s'posed to be 1.300, I can go up to 1.560v....is that right?
At the minute for this OC, I've got vcore set at 1.3875 in the bios (though spdfn sees it as 1.31)......
It just seems to me that, if my maths is correct (which it usually isnt
....) and those core temps are right, there seems room for an awful lot more - and as you can see, I'm at 3.68Ghz on my [email protected]!
My one concern as I said, is the Temp 2 reading.
Thanks for any input
