Advice on what I actually need not what I want !
17 Dec 2024
England
Hey all,
I'd be grateful if someone could give me some guidance and common sense. I'm after a new PC, will be for general office stuff, photo editing and some gaming. Nothing flash, so examples would be Farm and Truck simulator, Skyrim, Football Manager Diablo IV....
My instinct is to get something like a 7800X3D processor, RTX 4070 Super GPU, for the reason of 'just in case'....I know this will be massive overkill but there's always the what if kind of thought.....
I could spend £1800 or so but it's a lot of dosh if I don't need to spend that much.
For what I want can someone point me to a processor / GPU combo that would be what i should buy, not what my aspirational brain wants to buy !
Thank you.
For the price I'd recommend a 7700x. Your not playing hugely demanding games, I know the x3d chips can make the average 1% lows higher meaning smoother frame rates but the 7700x is no slouch in itself and costs considerably less.
There is a lot of hype regarding x3d chips and it is warranted, but the 7700x performs better in workloads, and is roughly on par close to the 5800x3d in games.
The 4070 super is a good choice, an AMD 7900xt would probably be an alternative to this
At that resolution I'd agree with this. Would be able to drop in a cheap upgrade years down the line, which is what I did on AM4
AMD build idea.
My basket at OcUK:
Total: £1,344.88 (includes delivery: £0.00)​
You could change to a rtx 4070 super if you use any software for photo editing that use CUDA.
Overkill cooler for a 7600 but it will scale with any upgrades.
Items that are pre-order can be had cheaper from other stores.
NO rgb as its an office machine.
Resolution is 5120 x 1440
Refresh rate 144hz
It's a Philips Evnia 49M2C8900L monitor.
I’d say a CPU with 8-16 cores, 32-64gb of RAM a motherboard that covers all the main food groups and a graphics card with a decent amount of VRAM.
Ryzen 7900X 12c 24t
Half decent A620 motherboard
2x16gb 6000 cas30 memory
Good quality 750 bronze PSU
1-2tb SSD
2-4tb HDD
A case with at least 2x front 120mm fans or better and at least 1x 120mm rear or better
RX 7900 GRE
RX 7800xt
RTX4060ti (16gb)
Intel Arc B580.
Probably in that order.
The Intel card is only 12gb which really is a weakness past 3 megapixels or so. The others are all 16gb, although check the 4060ti as some only have 8gb.
