Advice on what to do next?
13 Jan 2004
Leicestershire
Hi guys -
Athlon II 630 - 2.8ghz stock
Running at 250fsb x 14 = 3.5ghz
Motherboard - cheap Biostar runs up to 1600 DDR3 and has SATA 2
RAM - 8gb Gskill 2133mhz (2x4gb) - running at 1333mhz as 1600mhz stops it booting due to BIOS conflicts.
In future i will be buying an Asus m/board and a SSD (which is why i got the RAM (as the Asus board supports 2133mhz RAM)
What should i look at next as i don't really understand overclocking any more - latest PC i overlocked was a S939!
no one? I have lots of options in BIOS too which i can enable so not sure. Will try to remember to write them down so i can check them.
