Advice on what to upgrade please - or new system?
29 Mar 2004
So my current system is as follows:
"Krypton Baronyx" Intel Core i7 2600K 3.40Ghz @ 4.60Ghz Overclocked Bundle
8Gb Memory
MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card
OCZ Vertex 3 240GB 2.5" SATA-3 Solid State Hard Drive
Dell UltraSharp U2713HM 27" Widescreen LED Monitor
Corsair HX 620w
My budget is probably around £2000 and the PC will mainly be used for gaming (Battlefield / Anthem etc)
Any advice would be greatly appreciated.
Thanks.
8Gb Memory
Corsair HX 620w
Thanks.
looking for new case? if not whats your case ?
looks like monitor is 1440p IPS 60hz non sync screen
PSU is tier B (2018)/ Tier 2 so still a good one though guessing out of warranty?
You could double the memory (minimum) update the GFX card and maybe add a better/faster/larger SSD to that.
But with a 2k budget you could buy a whole new system (though the performance increase over the upgrade might not justify such a large budget)
half good shout, specially with Ryzen 3000* coming June . could just splash on RTX 2080 and 1TB SSD - up PSU to new 650w with new 7-10 yr warranty
PSU
Case is an Akasa Eclipse 62
Should I sell the monitor and get 2 new replacements (any advice on this)?
PSU is out of warranty now I think yes.
Here are a couple of suggestions if you want to go down the new system route.
Intel 9700K and Vega 64 with 27" 1440p 144Hz Freesync screen.
My basket at Overclockers UK:
Total: £1,936.12 (includes shipping: £15.30)
Same as above but with a Ryzen R7 2700X cpu and X470 board.
Total: £1,917.12 (includes shipping: £15.30)
You could always stick with your current Dell screen if 144Hz isn't important to you.
As mentioned by the Guys above you could easily just swap out a few things (GPU, Case and PSU and add extra Ram etc) and keep most of your current system intact.
