Advice on what to upgrade
20 Nov 2023
London
Hi
I have a PC which I have no idea really if it is capable of gaming at any level. I am a total newbie with any of this. I have a Intel core i7-8700K cpu @ 3.7GHz and just the Intel UHD graphics 360 card. What would I need to improve on for gaming and speed of my PC?
If you stick a RX 6600 in that PC, it would play pretty much anything @ 1080p.
What is the motherboard, RAM and PSU?
That is the info for the PC
OS Name Microsoft Windows 10 Pro
Version 10.0.19045 Build 19045
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-A6JNS3J
System Manufacturer System manufacturer
System Model System Product Name
System Type x64-based PC
System SKU SKU
Processor Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz, 3701 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 0416, 19/10/2017
SMBIOS Version 3.0
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Product TUF Z370-PLUS GAMING
BaseBoard Version Rev X.0x
Platform Role Desktop
Secure Boot State Off
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale United Kingdom
Hardware Abstraction Layer Version = "10.0.19041.3570"
Username DESKTOP-A6JNS3J\benso
Time Zone GMT Standard Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 21.3 GB
Total Virtual Memory 36.6 GB
Available Virtual Memory 24.5 GB
Page File Space 4.75 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualisation-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and the device is not Modern Standby, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualisation Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
Motherboard and ram are fine. Motherboard seems decently large, so I assume there's plenty of room in your case for the graphics card?
What is the PSU?
For reference, a 500w should be enough to drive that with some overhead. Using a RX6600XT and an SSD, 7200k SATA, three fans should see you pull 350w and with some overhead 500w will be fine.
However, thinking ahead, it you need to replace it, a decent 750w should probably be your minimum to aim for.
Let us know what you have and we can make a recommendation based on that feedback
