- 16 May 2004
- Derby
Hi.
Currently having issues with Wifi with some of the kids equipment. So I am going to go with wired connections.
Situation as it stands right now. Virgin media M250 (with Volt addon)
Virgin Media modem/router (no issues with it, works well) is situated in the living room. TV, PC, Xbox X are all connected with ethernet cable to router via a network switch box thing (netgear one, has 1 input and 4 outputs) All this is in the same room as modem/router.
Upstairs using WiFi I have 3 Tvs and 2 Xboxs. These are all taking time to connect/dropping/slow.
What is the best way to get all the upstairs stuff connected? disregard all wiring and installation, its just the way to connect it all I am needing.
Am I right in thinking just to get a larger ethernet network switch box, use one of the routers ports to connect to it and run 5 cables from network box to the stuff upstairs. (one of the routers ports is used to connect to my pc directly and another to the 4 port network box for the tv and dowstairs xbox.
, but thats fixed by literally holding the phone closer to the bathroom wall when sat down.... go figure.
