the whining sound from my H100 is driving me mad so ive decided to dump it and get a proper WC setup
ive decided to go with the XSPC RayStorm block and the XSPC EX240 rad
im using a Silverstone TJ09 which is not the best case for water cooling so i think my only option regarding the pump/reservoir is one of those 5.25 bay jobbies
but im not sure which to get
the full raystorm kit comes with XSPC D5 Dual Bay Reservoir which cost £120
while with the Rasa kit which i considered in the past you get the XSPC X2O 750 Dual 5.25” Bay Reservoir Pump which is half the price
i currently plan to cool a 2700K @ 4.8 1.34v but i do have a 670 SLI setup which i might WC in the future (i can add a extra 120 Rad easily enough)
Is the more expensive pump worth the massive price difference also is there anything else in the build i can improve on
Thanks
Thanks
