Hello
i hope you guys can advice me
I am running a 3rd gen i7 3700k stock speeds at the moment, 16gb ram 1 xGigabyte windforce gtx670 stock OC speed, all on a ga-z77x-ud5h
the machine is running very nice both in windows 7 64 and OSX ML.
The question i have is would getting a second Gtx 670 wind force running in sli make much of a different with games (windows only) I am a little disappointed TBH as I think it won't be long before I find the new games will struggle running with max settings, an example is the new Crysis 3, yes i no that this has it problems at the moment, but its the start of the new gen stuff and i would really like to no that i can run a game to its fullest.
any suggestions or advice would be great
thanks for your time reading this,
I understand that there are 3 slots for gpu's, are you saying that there is no need for me at the moment, to get a second 670 and that i should stick with just the one at present?
and this is what has made me concerned as this is now the benchmark. its player able but 30 is a bit low really.
