A bit of advice required on whether the current order for memory is going to work well. I've ordered this motherboard along with a Sapphire GTO2 card and an Athlon 3700 san diego CPU(both of which I'm going to modestly oc). At the moment I've ordered the paired mushkin ram
the blue ones)
Frequency: 400MHz Latency: 2-3-3 Parity: Unbuffered
Voltage: 2.6V - 2.8V Pins: 184
Density > > > Module: 32Mx64 Chip: 32Mx8
This 32X64 HP3200 module is an unbuffered 184-Pin Double Data Rate (DDR) Synchronous DRAM Dual In-Line Memory Module (DIMM), organized as a single-bank high-speed memory array. 32Mx8 chip density. This DIMM achieves high-speed data transfer rates of up to 400MHz. Rated 2-3-3 at 400MHz.
I've future proofed with the motherboard for future SLI setup but is this ram any good or what else would you recommend.
yours
Stuart
yours
Stuart
