This is my first post on this Forum. You all seem very knowledgeable and helpful, so can I ask for your advice please?
I’m currently running a 4770k oc'd to 4.5 Ghz, Z87 Sabretooth mobo and EVGA GTX 780SC. When I built this a couple of years ago it was reasonably cutting edge… I kept the 24” Iiyama monitor I bought in 2009 from the previous build.
I mostly fly flight simulators, especially MS Flight Simulator X and BMS 4.33 (Falcon 4) at max settings, with the odd bout of Arma 2. But I’m open to becoming a bit more of a “gamer” and try some modern games with fabulous eye-candy!
I’ve just donated the Iiyama and the old E8400 rig to my wife so she can write her best-selling novel on it, so I’m without a monitor.
So my plan was to upgrade either to a 27” 2560x1440 with G-Sync, or maybe a 34” 21:9 3440x 1440 monitor, and drive it from the GTX780. If that proved inadequate, upgrade it to some flavour of EVGA GTX 1080.
However I’m dismayed at the legions of you guys (and not just on this Forum) who have been obliged to make one or more RMAs for “back-light bleed”, “bad pixels” etc. I’ve never seen so much dissatisfaction with any other class of PC component.
So while I appreciate the dangers of falling into the “just wait for the next big thing” syndrome, I wonder if I wouldn’t be better at this moment just buying a cheap (@£150) and cheerful 27” 1920x1080 TN monitor (eg AOC's E2770SH) from OCUK and waiting for say 12 months.
By this time hopefully (a) there’ll be more choice of 21:9 G-Sync monitors; (b) and cheaper (though price isn’t a primary consideration); and (c) quality assured. At the same time I could upgrade to a GTX 1080.
Is this dumb, or sensible? What would you advise me to do?
Many thanks
Alan
Many thanks
Alan
