Advice please: upgrade capability
16 Apr 2008
Hello folks
I'd appreciate some advice please, because its been a couple of years since I did any upgrading tasks.
Current system:
Current case is M-ATX Antec Minuet with a 220W PSU
Current CPU is 2005 vintage Celeron 2.8G
Current Mobo is Asus P4S800-MX
Current use is basic office stuff, occasional video
NO gaming or 'high demands', some photo editing.
My plan:
Keep the case and PSU
Change CPU to Intel Conroe E6750 2.66G
Change Mobo to Asus P5E-VM with o/b graphics
Planned use: same basic stuff, but now driving a 1900x1200 widescreen, hence need a boost, but nothing too fancy (no games, remember).
My questions:
(1) Will the 220w PSU be sufficient for above? Currently runs fairly cool.
(2) What's your general opinion?
Thanks
Welcome to the forums.
No, your PSU will not be enough really at all. I would recommend a new far more beefy one.
Personally I would say something like :
http://www.overclockers.co.uk/showproduct.php?prodid=BU-106-OC
That kind of combo (or variation of) will be best.
Or, if you wanted to save some money, get the E2160, the same board and ram. No in built GPU I hear you cry! just get anything light wait, something like:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-152-AS&groupid=701&catid=56&subcat=168
or
http://www.overclockers.co.uk/showproduct.php?prodid=GX-073-OK&groupid=701&catid=56&subcat=1010
Overclock the CPU though. Even the 2160 could probably get 3GHZ on stock cooler.
So basically:
PSU (I personally like corsair or OCZ)
2GB ram (I like Geil or OCZ or corsair)
Motherboard (asus or gigabyte are great boards)
E2160 on budget, if you want to spend more then consider the E6600 Quad.
Whatever GPU you want.
AMD Athlon 64 X2 Dual Core 4600+ 2.40GHz (Socket AM2) - Retail AMD Athlon 64 X2 Dual Core 4600+ 2.40GHz (Socket AM2) - Retail £39.99
(£46.99) £39.99
(£46.99)
Gigabyte GA-MA78GM-S2H AMD 780G Micro-ATX (Socket AM2) PCI-Express DDR2 Motherboard Gigabyte GA-MA78GM-S2H AMD 780G Micro-ATX (Socket AM2) PCI-Express DDR2 Motherboard £52.99
(£62.26) £52.99
(£62.26)
OcUK Huntkey 450W PSU OcUK Huntkey 450W PSU £31.99
(£37.59) £31.99
(£37.59)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £22.99
(£27.01) £22.99
(£27.01)
Sub Total : £147.96
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.95
VAT is being charged at 17.5% VAT : £27.46
Total : £184.37
This should do. That mobo has probably the best integrated graphics at the moment.
