Advice please.
26 Nov 2003
Whats the best sound card for someone on a budget or is there not much difference between the sound devices on a TOP end motherboard and medium range seperate sound card. I only use headphones most of the time anyway. Does certain sound cards allow more sound with specific games??
Usual
Good sound does not have to come externally. You will find the neo range boards from MSI have top notch sound. But then again the external Audigy boxes are PERFECT! ... Depends what you gunna be using it for ?
