20 Nov 2006 at 16:57 #1 milkinc13 milkinc13 Soldato Joined 16 Apr 2006 Posts 3,213 Location Basingstoke what would be the better software for internet security Kaspersky or Norton. All advice will be appreaciated. Thanks Phil
20 Nov 2006 at 17:06 #2 modo77 modo77 Soldato Joined 31 Aug 2004 Posts 3,656 Location Sol System Norton is one of the worst one out there. Karspersky and NOD32 are the best, however these are only AV. So you'll need a firewall too.
20 Nov 2006 at 17:09 #3 milkinc13 milkinc13 Soldato OP Joined 16 Apr 2006 Posts 3,213 Location Basingstoke I was thinking of getting Kaspersky Internet Security 6.0 which does have a firewall.
20 Nov 2006 at 17:11 #4 modo77 modo77 Soldato Joined 31 Aug 2004 Posts 3,656 Location Sol System ah does it, thought it was just AV. Well deffo go with that then.
20 Nov 2006 at 17:21 #5 daveydave daveydave Soldato Joined 1 May 2006 Posts 2,583 Location UK windows firewall is enough to be honest and also kaspersky Av has a web anti virus which monitors all sites you visit
20 Nov 2006 at 17:21 #6 milkinc13 milkinc13 Soldato OP Joined 16 Apr 2006 Posts 3,213 Location Basingstoke thanks for your help modo77, do you know of anywhere in the UK where I can purchase it from so I can get next day delivery? Thanks Phil
20 Nov 2006 at 17:24 #7 modo77 modo77 Soldato Joined 31 Aug 2004 Posts 3,656 Location Sol System yeah direct from them, and you can get it now http://www.kaspersky.com/store
