- 18 Oct 2002
- South, Scotland
Ok so this is my current spec:
Q6600 Stock
Asus Blitz formula (P35)
4x 1GB Crucial PC8500 DDR2
8800GTX OC2 765MB
I mostly play World of warcraft with other games like Supreme Commander, I want to play Crysis and other newer games. But I display them on a 24" Dell 2407WFPmonitor at 1920x1200. I dont want to run the resolution at less so I'm considering an upgrade.
My PSU is more than capable at 720W (Enermax Infiniti EIN720AWT) so I'm going to base an upgrade on a 4870x2 card when they hit soon. But from some threads on various sites the advice is that a PCIE 1.1 board with a slow CPU will throttle this cards performance.
I think my Q6600 has more to give, its currently being cooled by a Thermaltake Big Typ VX. My CPU seems to be idling at 50 degrees in windows which is being reported by CoreTemp 0.99.
Seems a bit high for idle, but it got worse with Prime95 where the hotest core was reported as 85 degrees.
WOW even when being used fully to the point the FPS drops isnt making the CPU go above about 65-68 degrees though.
I'm a bit worried that if I over clock the Q6600 it will not last long. When I play WOW I raid in high end 25 man instances where I can see frame rates drop to 10-15fps. So I'm looking to increase that.
So really I'm looking for advice on what to do now, also I run a dual monitor setup
Q6600 Stock
8800GTX OC2 765MB
