Advice Please.
3 Jul 2014
Cheshire
Which Broadband provider would you recommend?
I used to be with 02 and was happy with them, I got 7 meg download speed
and never had a problem. Paid £9.50 a month which I thought was a bargain.
Sky took over O2 and I paid the same price. Soon after my speed flopped down
so much it was unusable. They couldn't sort it out and refused to send an Engineer so I cancelled with them.
I decided to try BT and signed up for their Unlimited 76 meg package.
To cut a long story short my router keeps on cutting out and I can only get 20 Meg speed at best.
Any advice would be appreciated
Contact BT and see what the problem is. Could be a faulty router, faulty line or any number if other issues.
Update: Had an Engineer out today. He said that the last engineer had wired it up all wrong.
Getting 76 Meg speeds now and router not cutting out. I must add that BT have great customer service. Very impressed, not so impressed with the first engineer they sent though.
+1 had a few bad exp with bt years ago, but the time on fttc never one problem, bar the re sink at 2400 most nights then its fast as till 0700
