Advice please
7 Apr 2015
Havn't built or touched a desktop in over 10 years. Recently have an urge to play CS: GO with a friend and the laptop and mouse isn't cutting it.
Could someone spec me something decent, dosn't have to be top spec. will only be used to play CS, Rainbow 6 when its released. apart from that it'll not be used i don't think. Had a look at the OC bundles but having been out of pc building for a while i dont know whats good and whats not
Thanks
Hi and welcome.
So you know how to build a PC?
DO you have a budget?
What parts do you need? (tower/OS/keyboard etc)
YOUR BASKET
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£12 Saving** £269.98
1 x Gigabyte GeForce GTX 970 WindForce OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N970WF3OC-4GD) £259.99
1 x Crucial BX100 250GB SSD SATA 6Gbps 7mm Solid State Drive (CT250BX100SSD1) £74.99
1 x Antec TruePower Classic 550w '80 Plus Gold' Power Supply £53.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) £47.99
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) HDD £41.99
1 x Antec GX500 Midi-Tower - Black £32.99
1 x Raijintek Aidos Direct Contact CPU Cooler - Black £14.99
Total : £819.82 (includes shipping : £19.10 Ex.VAT).
if you do need a copy of windows,
YOUR BASKET
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £79.99
Total : £87.73 (includes shipping : £6.45 Ex.VAT).
And you may or may not want to add a DVD drive (windows can be installed via USB thumb drive).
What resolution is your monitor?
YOUR BASKET
YOUR BASKET
The monitor is 1920 × 1080 its a BenQ Rl2455HM and thanks ill hve a look at those parts! :D
I've decided to do some reading up and want to kind of go awol as you do, is this a decent spec or a really good spec the GPU will either be 980ti or the titan x :)
Your basket
Product Name Qty Price Line Total
"Titan Envy M Evo" Intel Core i7 4790K @ 4.4GHz Overclocked Nvidia GeForce Gaming PC "Titan Envy M Evo" Intel Core i7 4790K @ 4.4GHz Overclocked Nvidia GeForce Gaming PC £749.03
Options applied to the above product:
Kingston HyperX 16GB (2x8GB) PC3-19200C11 2400MHz Dual Channel Kit - Black/Red (HX24C11BRK2/16-OC) £125.99
Seagate Barracuda 1TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £44.99
Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU) £89.99
OcUK GeForce GTX 980Ti "Reference Design" 6144MB GDDR5 PCI-Express Graphics Card £539.99
Phanteks Enthoo Evolv Micro-ATX Case - Gun Metal £99.95
ESET Smart Security - Trial Key £0.00
OcUK Standard System Warranty - 3 Year (24 Month C&R + 12 Month Labour) £0.00
Standard Build Systems - Dispatched within 7 working days £0.00
Total : £1,744.92
Thanks
