Advice please....
What monitor do you game on? Do you plan on going freesync or G-Sync in the future? Depending on your future plans will influence what brand of card you should buy.
I was going to suggest exactly this myself.
As others have said OP, get the fastest single card in your budget. Don't do Xfire, it'll just cause headaches.
+1 the 480 will muller the 7970, probably even if you XFire 2 of them.
