Hi I have decided to upgrade my 3200+ to a X2 4400+ CPU.
This will be the first time I have ever installed a CPU on my PC so I was wondering if any one could answer any of the ?`s below.
1. If I wanted to can I use the CPU fan that is currently installed on my PC with my 3200+ or would I need to make sure I use the fan that was made for the 4400+ ? - Its just that I am not to sure If a fan is included from the place I bought my 4400+ from.
2. thermal paste - do I just spread it all over the chip or just in certain places ?
3. Is it as easy as take my fan off my old CPU, put my new CPU in, throw some paste on top and put the fan back on top of it, then just upgrade my bios to the version that supports this new chip and thats it ?
4. I take it you guys who overlcok your CPU`s use some sort of software which will allow you to change the defualt settings to increas the speed of the chip ? IF so what software do you use ?
thanks for help people !! I did try to order the 4400+ threw this site but my card wont go threw for some reason so was forced to buy else were.
Hope this doesnt stop you from helping me
even thou all my upgrades have been bought from this site
