got me self one of these XSPC RayStorm D5 RX360 V3 kits
on the d5 Vario pump thier is an blue wire techometer wire and the other wire goes on an molex they say place the blue wire on the motherboard fan header. is this ok on the cpu fan header ?
at the moment am only cooling the cpu and at a later stage i shall do the gpu
on the back of the pump their is selector for the pump speed i got it on no: 2 is that ok for just the cpu noise and temps are ok idle around 28-30 load am running around 55-60 @ 4.6 oc
thx
thx
