I've just got my hands on a ThermalTake Lanbox (VF1000BWS), and as I'm currently unable to upgrade to anything fancy, thanks to budget restraints, was considering either moving my current build out of the Lian Li PC-65 into it, which still runs all I need without a hitch, or preferably purchase something in the same lines, which would perform just as well, and cost a minimal amount. The latter would offer the convenience of not leaving other users without the current build mentioned, every time I took the Lanbox on the road. Problem I'm finding is which hardware; in the case of a move from the PC-65 to the Lanbox, is there isn't much in availability, of a decent Socket 939 MATX Motherboard, for cheap, and I'm thinking, an AM2 won't do, because of my CPU, also, if going with a new build, what, AMD or Intel, and what, that would offer me the same kind of performance as my current build, with the expectation that it would / should make it a fairly cheap investment?
Your thoughts please!
