I read it as the board has a 24 pin and the psu has a 20. In which case first buy a 20 to 24 pin adaptor and if you run into problems get a new psu.Yellowbeard said:Your 24 pin plug should be segmented so that you can remove it or use it safely in a 20 pin ATX plug. It should work fine assuming the PSU meets the MOBO specifications and that the MOBO is not too old.
Yeah, I skipped that part. It will be a block of 4 empty pins left empty on one end of the MOBO socket. And, as you pointed out, the pins are keyed so that you can only plug the socket in 1 way.Joe42 said:I read it as the board has a 24 pin and the psu has a 20. In which case first buy a 20 to 24 pin adaptor and if you run into problems get a new psu.
If you were to plug it in without a 20 to 24 pin adaptor there should not be 2 pins left blank at each end but 4 at one end. It will only fit one way.
