Hi all just looking for some advice regarding my batch script i have created. I have added a goto menu to the script so it will ask which backup drive i want to backup files to. I have set it to go to backup drive 1 upon the number 1 being pressed and backup drive 2 upon the number 2 being pressed. The problem i have is whenever i press the number 2 option to backup to backup drive 2 it seems to go to the backup drive 1 menu instead of the backup drive 2 menu
Sorry if i sound confusing, i have put the script below for you to see.
Hope someone might be able to help
ECHO WHICH BACKUP DRIVE WOULD YOU LIKE TO BACKUP YOUR FILES TO?
ECHO ------------------
ECHO BACKUP DRIVES LIST
ECHO 1. BACKUP DRIVE 1
ECHO 2. BACKUP DRIVE 2
ECHO.
SET /P N=TYPE 1 FOR BACKUP DRIVE 1 OR 2 FOR BACKUP DRIVE 2 THEN PRESS ENTER:
IF "%N%"=="1" GOTO BACKUP DRIVE 1 WIZARD
IF "%N%"=="2" GOTO BACKUP DRIVE 2 WIZARD
:BACKUP DRIVE 1 WIZARD
ECHO MY MOVIES BACKUP
ECHO THE FOLLOWING FILES WILL BE COPIED FROM MEDIA DRIVE 1 TO BACKUP DRIVE 1
XCOPY "D:\My Movies" "\\LIAM-MEDIA\Backup Drive 1\Movies" /L /D /Y /S
PAUSE
XCOPY "D:\My Movies" "\\LIAM-MEDIA\Backup Drive 1\Movies" /S /D /Y
ECHO.
ECHO THE FOLLOWING FILES WILL BE COPIED FROM MEDIA DRIVE 2 TO BACKUP DRIVE 1
XCOPY "F:\My Movies" "\\LIAM-MEDIA\Backup Drive 1\Movies" /L /D /Y /S
PAUSE
XCOPY "F:\My Movies" "\\LIAM-MEDIA\Backup Drive 1\Movies" /S /D /Y
ECHO.
:BACKUP DRIVE 2 WIZARD
ECHO THE FOLLOWING FILES WILL BE COPIED FROM MEDIA DRIVE 1 TO BACKUP DRIVE 2
XCOPY "D:\My Movies" "\\LIAM-MEDIA\Backup Drive 2\Movies" /L /D /Y /S
PAUSE
XCOPY "D:\My Movies" "\\LIAM-MEDIA\Backup Drive 2\Movies" /S /D /Y
ECHO.
ECHO THE FOLLOWING FILES WILL BE COPIED FROM MEDIA DRIVE 2 TO BACKUP DRIVE 2
XCOPY "F:\My Movies" "\\LIAM-MEDIA\Backup Drive 2\Movies" /L /D /Y /S
PAUSE
XCOPY "F:\My Movies" "\\LIAM-MEDIA\Backup Drive 2\Movies" /S /D /Y
ECHO.
ECHO.
PAUSE
ECHO.
PAUSE
ECHO.
PAUSE
ECHO.
PAUSE
ECHO.
