Hi guys maybe you can point me in the right direction or suggest a better alternative as I'll explain.
I've just recently completed a new custom build using the Ryzen 5 2600X and Gigabyte B450 Aorus M, plus 16Gb 3000 MHz RAM and GTX 1060 3Gb as the base.
Everything is working fine just as expected so no issues there except I don't particularly like the effectiveness of the stock Wraith Spire cooler which comes with the CPU.
I don't bother with overclocking so the CPU cooler isn't being pushed beyond its capabilities but the CPU cooler fan seems awfully busy when the CPU gets a bit of work to do, which didn't happen with my old system ( Phenom 11 945 BE) even though it was quite hot running chip.
I did replace the original stock cooler on the Phenom with an 'Arctic Freezer 7Pro' as the original stock cooler itself was awful good and got quite loud with the CPU under pressure but the fan pitch barely showed any change once I'd fitted the Arctic cooler and I'm wondering if a different cooler might also be a better option than the stock Wraith Spire supplied with the 2600X?
I don't think I want to go down the water-cooled option just yet as the temperatures aren't excessive ( according to 'Core Temp' software) as at idle it can be as low as 32 degC but can shoot up to over 70 when I'm moving lots of photo image files around USB drives.
I had a quick game of World of Tanks just a few minutes ago and the CPU never got hotter than about 52 deg C and again, around only 60 degC for CS:GO so it's certainly not too bad under normal gaming loads and well under the limits for the CPU.
I also checked carefully how I installed the Wraith cooler, being extra careful not to damage the pre-applied thermal paste as I put the cooler into place and tightened the cooler evenly so that isn't an issue and it can't be due to overheating of the case as I've had both sides off as I've been swapping drives etc around and there are three cooling fans working besides the CPU fan.
I do prefer a cooler which has a fan that exhausts the air over the cooling fins in parallel to the CPU and mobo surface rather than at right angles so that I can pull the air passing over the CPU cooler fins and out of the case through the case roof via the top fans which is how I had my last set up configured.
Maybe I just got so used to my old system being so quiet and effective that perhaps I'm expecting too much from the new set up but I confess that it does irritate me somewhat when the house is quiet and I hear the sound of the CPU fan constantly rising and falling in pitch as the load changes often for what seems very little reason.
Ideas please!
Ideas please!
