Hi, the question is similar to Spellcaster1972's but I've started a new thread as I have an older CPU so I may get different advice.
Anyway my system is:
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
Kingston HyperX 4GB (2x2GB) DDR2 6400C5 800MHz Dual Channel
Nvidia GTX460 768MB
Windows XP sp3
I would like to upgrade the CPU but not go to the expense of getting a new motherboard as well, this is because I'm also going to be getting Windows 7 and all together it would all be a bit too expensive.
I am looking at either
Intel Core 2 Duo E7500 LGA775 'Wolfdale' 2.93GHz (1066FSB) or Intel Core 2 Quad Q8300 LGA775 'Yorkfield' 2.5GHz 4MB-cache (1333FSB)
I do not want to spend more than £100 but want to have something that will last another year or so before I upgrade again.
I generally use the PC for games and the age of the CPU is starting to show with new games like Shogun 2, and I intend to buy the Witcher 2 soon so will need a bit better CPU than I currently have.
Nvidia GTX460 768MB
Windows XP sp3
I stopped bidding at £60 and got one off the MM instead. Silly money they're going for still. Wolfdale chips are good though, 45nm and good amount of L2 cache.
