- 6 Jan 2013
- Rollergirl
I'm just looking for a little pointer, I'm not trying to push every ounce out of my chip, I just want to make sure I'm getting good performance.
Spec:
I've got the CPU at 4.3GHz/1.35v and I'm happy with that. Memory is at 2666MHz.
I'm looking to push the ring bus, but not sure where to set it in terms of frequency, and which voltages to tweak to support it.
I can provide screen caps of BIOS settings if required.
TIA
Spec:
- ASRock Fatal1ty X99M Killer Micro ATX
- 5960x
- 32GB Corsair Vengeance
TIA
