- 7 Jun 2006
Im going to uni soon so I've diverted £1500 my savings to investing in a new machine that will last me for the next 4 years!
Now Im an advid gamer and cant do without them, I'll also be running demanding software like virtual PC on various operating systems, no doubt eventually vista.
I've been looking to buy a premade system, there prices are brilliant and I've specced two machines which I'll list below, Id like your advice on which would serve me better and which is most future proof and less likely to explode over the next 4 years?
The main difference between the two systems is the GFX card and CPU, one being a new Intel Conroe the other being an AMD FX60 also with a beefy(er) graphics card.
Which will perform better for games?
Is the £200 extra for spec 1 worth it?
Any suggestions to what else I could add/remove? A better price from somewhere else perhaps?
Spec 1
CPU
AMD® ATHLON® 64BIT FX60 @ 2.6GHZ 2 x 1MB L2 Cache (939 pin)
Memory
2048 MB CORSAIR DDR400 PC3200 - LIFETIME WARRANTY!
Motherboard
ASUS® A8N-E/M2N-E: DUAL DDR, S-ATA, x16 slot, 3 PCI etc
USB Options
SIX USB 2.0 PORTS (4 REAR + 2 FRONT)
Hard Drive
SATA II 250 GB HARD DISK @ 7200rpm 8mb cache
Second Hard Drive
NONE
RAID
NONE
DVD ROM/Combi Drive
16X DVD ROM WITH 48X CD ROM
CD/DVD Writer
NONE
Graphics Card 1
1024MB GEFORCE 7950GX2 (DUAL GPU) PCI Express + DVI + TV-OUT
Graphics Card 2
NONE
Sound Card
HIGH END ONBOARD 8 CHANNEL SOUND (RECOMMENDED)
Modem
NONE, I WILL BE USING BROADBAND
Network Facilities
10/100/1000 NETWORK CARD FOR BROADBAND
Floppy Drive/Card Reader
1.44MB FLOPPY DISK DRIVE
Case
Stylish Silver/Black Trident case + 2 front USB
Power Supply & Cooling
500W (Peak) Super Quiet Dual Rail PSU + 120mm fan & CPU Cooler
Price £1451
Spec 2
CPU
INTEL® CORE® 2 DUO E6700 (2 X 2.67GHZ) 1066mhz FSB/4MB Cache
Memory
2048 MB CORSAIR DDR2-533 PC4200 - LIFETIME WARRANTY!
Motherboard
ASUS® P5W DH DELUXE: DDR2, x16 slot, 975X chipset, 3 PCI
USB Options
Hard Drive
Second Hard Drive
NONE
RAID
NONE
DVD ROM/Combi Drive
CD/DVD Writer
NONE
Graphics Card 1
512MB GEFORCE 7900GTX PCI Express + DVI + TV-OUT
Graphics Card 2
NONE
Sound Card
Modem
Network Facilities
2 x 10/100/1000 GIGABIT LAN PORTS ONBOARD
Case
Operating System required
NONE
Firewire & Video Editing
1 x FIREWIRE PORT ONBOARD
Price £1278
Thank you so much in advance for your replies.
Spec 1
CPU
Memory
Motherboard
USB Options
Hard Drive
Second Hard Drive
NONE
RAID
NONE
DVD ROM/Combi Drive
CD/DVD Writer
NONE
Graphics Card 1
Graphics Card 2
NONE
Sound Card
Modem
Network Facilities
Case
Price £1451
Spec 2
CPU
Memory
Motherboard
USB Options
Hard Drive
Second Hard Drive
NONE
RAID
NONE
DVD ROM/Combi Drive
CD/DVD Writer
NONE
Graphics Card 1
Graphics Card 2
NONE
Sound Card
Modem
Network Facilities
Case
NONE
Price £1278
not entirely my fault though it stuck big time to the vanilla cpu fan
